blue Gauge cluster...
b00stAdict
101
Jan 22, 2009
broomfield, Colorado
first off i have searched and searched and searched with no luck what so ever. im looking for a write-up on how to get my gauge cluster to look like this;
it looks like they are the stock gauges with just blue lighting behind, im not sure if they changed the bulbs, did an led swap or what. Just looking for some insight please :hellyeah:
thanks
Thats a great write up. I followed it but sanded off the orange from the back of the guage overlays and went one step more and put a thin blue film I got off ebay behind them along with the blue leds.
The sanding is the easy part. Getting to some of those light bulbs is kind of a pain. That and I was lazy and didn't figure out which side of the leds was positive and then test the switch to see which side was positive. I got it wrong probably 75% of the time. :ohdamn: Those little bass turds are hard to get out of some of those holes!
Yeah I just got my gambling bug out and what do you know the house always wins! Thats why I suggested checking the terminals and the leds before you try. I figured I had a 50/50 shot of getting it right and that caused alot more work than just checking and making sure it was right the first time.
The pic doesn't capture it very well, but this was done with natural white replacement LEDs (and 3 additional surface mounted LEDs), stripped and repainted needles, and blue/red stage lighting gels. The pic was taken with the cluster on the bench, while I was still working on eliminating the hot spots and dialing in the color.
All of the HVAC and other lights were also removed and customized with various types of white LEDs.
Its just blue leds. Buy the leds check the data sheet for them and use ohms law to calculate the correct resistor needed for protection.
also there is a anode and cathode, every led should have one leg longer than the other. The longer leg goes to the more positive voltage source.
Sent from my DROIDX
Its just blue leds.
The cluster I just posted a pic of doesn't have any blue LEDs.
The problem with just replacing the stock bulbs with blue LEDs is that it makes the needles and red lettering look weird. IMHO, if you are going to do blue gauge faces, you really need to disassemble the cluster and rework it, so that everything looks like it was designed that way.
It's a hell of a lot more work, but I think the end result is well worth it.
Better check your gas gauge your almost outta gas ;) LOL looks so good
Something a little more easy to get, for those like me who cant wait the 2 days ebay takes to ship LOL, is get colored transparent notebook dividers from walmart. thats how i got mine red!
LOL
That was actually a spare cluster that I used to mock everything up with. But... it does take some trial and error when you put it back together to get everything re-calibrated.
When I finished my actual cluster, I installed it in the dash without the plastic cover on it, and then positioned the tach needle and checked it against ECMLink with the car running. Once the car warmed up to my normal operating temperature, I placed the temperature gauge needle so that it was straight up.
For the fuel gauge, I drained the tank and then adjusted the needle position with some known amounts of gas to make sure it was correct.
BTW - The low gas light in my car comes on at exactly 2.5 gallons of fuel left. ;)
This pic doesn't have the gauge bezel around it but you get the idea. Its alot more blue looking in person.
if its that bright in person it will get old fast. i had done this in my old 3000gt and it got to the point where it was distracting when i was driving so i pulled them out and went with wider angle and frosted the lens of the leds.
Might want to check if the leds you are using like to be adjusted thru a rheostat. Not all of them do.
