Kalisko
- 267
- 0
- Mar 19, 2008
Lawrenceburg,
Indiana
So I just bought some steelies, and I guess even though it's the right lug pattern, i didn't think about this. Can steelies fit on eclipses? I was curious because I don't believe i have ever seen eclipses rolling on them
.. Well I went to put on the front wheels, the calipers hit the steelies. I'm thinking about ordering some wheel spacers, but i'll need 1.25 to 1.5" of spacer on to get these to fit probably. The back wheels have plenty of clearance, which is the first steel wheel pic. The last pic shows how the fronts hit the caliper.
I'm trying to figure out if anyone else has ever ran into this problem.
Do all steelies run into this problem, because most steel wheels I've seen have the same setup without spacing.
If so, would wheel spacers be a good idea? I've attached pictures to show how things line up. Thanks
.. Well I went to put on the front wheels, the calipers hit the steelies. I'm thinking about ordering some wheel spacers, but i'll need 1.25 to 1.5" of spacer on to get these to fit probably. The back wheels have plenty of clearance, which is the first steel wheel pic. The last pic shows how the fronts hit the caliper.I'm trying to figure out if anyone else has ever ran into this problem.
