needs some help
stewartfn1
May 5, 2011
villa ridge, Missouri
Ok some im pretty new to this DSM always built chevy products so here goes my question i have a 1g non turbo it dosnet want to run at all until the temp gauge shows that the car has warmed up a little after it warms up it run great have no problems until i let it sit and the car cool completly back down any suggestions would be great thanks
I would check the engine coolant temperature sensor and the wires on there, the wires tend to get crispy and break pretty easily! The car will be hard to start if those are bad or broken.the sensor and wires are at the coolant neck, where the top hose of your radiator connects. You can find lots of threads about this sensor on here too, hope this helps
