Need vacuum help
R3DN1NJ4
Nov 26, 2019
LAS VEGAS, Nevada
Hello all!
So I bought this DSM for my next project car to restore. Already did the engine swap and have the car running. But I have an issue with this code P1494. And I know it has to do with one of these vacuum lines that are not hooked up. Or hooked up wrong. I have no reference to go off since the two hoses were not even connected when I bought the car and didn't see any of them connected when I was at the junk yard to pull the engine so i'm at a loss to how these vacuum hoses should be hooked. Everyone I've seen online and on youtube has theirs deleted. But the thing is, I don't want the check engine light on.
Thank you!!
Solution
Mitsubishi stuck a vacuum diagram sticker on the underside of the hood. In case this is missing see the attched file "1997 Non-Turbo vacuum circuit diagram"
You dont give much info about the car such as the year or 4 liter or 6 , turbo or not.. Any ways , I have had much luck with letting my browser do the work for me... Example .. I typed in 2001 Mitsubishi Eclipse vacuum routing and this is what it gave me … https://www.bing.com/images/search?...1+mitsubishi+eclipse+vacuum+routing&FORM=IGRE
Maybe you could use the link as a staring point in your search.. Hope this helps
Thought that's what the car profile was for.........guess i'm just asking the wrong questions in my search?? But even still you will get different results then I would due to how the search algorithm is. Reason why I'm unable to find what I need.
Car is a 1997 Mitsubishi Eclipse GS 2.0L DOHC 420A
Solution
