Need to know how much power this set up could make
coastalbob
Sep 26, 2009
Columbia, South Carolina
freshley built 420a with a 2.3l stroker kit.
has knife edged crank and
manley h-beam rods.
motor is completely balanced and blueprinted with minor head work.
comes with a sheet metal intake manifold but needs to be port matched to the throttle body (not installed, but included, also comes with a low impedence injector harness).
has a star log manifold number 52 out of 254 made and a t4/t3 .50 turbonetics turbo. Turbonetics Deltagate wastegate,
Vortec fuel pressure regulator,
manual boost controller,
hks ssqv and
polished intercooler piping and same side intercooler.
2 3/4 downpipe to a n1 exhaust.
Msd ignition coil.
450cc injectors
Car is tuned on 8lb of boost with a safc.
Has autometer A/F gauge and boost gauge.
Greddy turbo timer.
Has a fully built TRE trans and a centerforce clutch.
GS-X front brekes
walboro 255fp.
18" adr wheels
The exhaust is a 2 1/2 inch n1
Not benchracing need to know because I might be getting the car.
Guy claims this set up is making mid 300hp.
Still bench racing.
If he says its 300hp, ask for a dyno sheet.
I just wanted to ask people that new about eclipses what they thought.
I've only been in the honda scene so I have no idea what this stuff is worth or anything.
I've always been afraid of dsm because they are known as unreliable
Thats a very uneducated assumption my friend. A 420a is more reliabe block wise because it's cast iron, making it stronger than aluminum honda motors. Just my .02.
I would suggest staying away from a car like that... 8psi making 300 hp is very hard to believe... My buddy just sold a very modded turbo 420a because of how hard it was to tune without going standalone..
Just put it together, break it in as it should be, give it a run and tell us of the outcome - only way you're gonna find out...
For, if all of this blows the doors off your vehicle, good for you. And if it doesn't, also good for you since it ran down the road.
For, guessing doesn't count around here ...
Your last post like this was closed for bench racing. We don't do it here.
