need some input
98GSt_4life
201
Dec 11, 2006
Orlando, Florida
ok my head gasket went bad on me and i need to know if i pull the pistons out and set them aside if i can put them back in using the same rings? im not honing the block, im just getting the block and head resurfaced. a few places said i should have no problems at all and other people have told me not to. 2 reasons i dont want to have to replace them. 1) i dont have any extra money 2) ill be puting in a new clutch so i wont be able to set the new rings properly.
If you have it apart I would change the rings because they will have a slight glaze on them. A new set shouldn't be more than $50. To answer your question, yes I have reused rings successfully, but its not the right way to do it.
Oliver
Sounds like a lot of work just for a headgasket eh. I would just have the head checked for warpage. To answer your question though they will be okay as long as you put the back in the same cylinders they come out of.
It's not that much work. I'm positive the heads warped because the problem started after it over heated. So I'm just getting both the head and block resurfaced to be safe sence I'll be using a MLS headgasket. Everythings marked and will be going in the same way they came out.
Did you by chance do a compression test before you took your engine apart? If so and the compressions were even and high enough, then you can reuse the rings, as stated previously, in the same cylinders as they were.
If you had perfect compression, why did you pull the head in the first place? Now that you've got it off, is there actually a break in the gasket at all?
I pulled if off because I was getting coolant in one cylinder. And when I took the radiator cap off and started the car it would get bubbly. I couldn't see any breaks in the gasket but there's no cracks in the block and the shop told me today there were imperfections with the head so it must have been the gasket.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
