Need some help with VPC and Wideband
Ok, if you hardwired your vpc; did you use resistors? If you didn't then your vpc will not work correctly. And yes, I've seen instructions online where people used different airflow signal wire to use with air fuel controller. That method did not work when I tried it. On resistors, I don't know which ohm resistors they are exactly but it could be 2700 ohm and 900 ohm. Not sure. Hope someone else from here could help out on that.
If the resistors are correct then 2700 ohm will need to be soldered between pin 72(intake air temp sensor) and 92(sensor ground). 900 ohm resistor will need to be soldered between pin 81(sensor impressed voltage) and 85(barometric pressure sensor).
I have the resistors soldered in as well. I actually had 3 of them total but on the install guide I was using it used 3 so I thought it was normal. Its just weird how the car will start and idle like a champ but if you so much as put your foot on the gas petal it will kill it. Plus the tps isn't working despite putting a new one on and trying to adjust it. I'm at my wits end with all this
