Need some opinions (VPC+GCC vs. SafcII)
andymac40330
177
Sep 4, 2007
Harrodsburg, Kentucky
So basically as the title states I as of now have the SAFCII but I have an offer to make a straight trade for a vpc+gcc combo. I am planning on running 850+ injectors and the largest rom I can find for the vpc is 660. I was wondering if this would still be a better combo for my car or if I should stick with the safcII and go the keydiver route?
Vpc/gcc has been proven into the 9s. Its old technoligy as alot of people will say, but its proven. The 660 chip is not needed, 550cc chip in the vpc is enough, THE 660CC chip has aggresive timing good for race gas. I run the vpc and afc 2 for now. I also have a chip from dsmchips set up for the vpc/550cc chip 880cc injectors etc. which is what your gonna have to do to run those injectors
go with the vpc/gcc the only thing is you will need a chip for the injector size you are running. vpc is speed density alot better then safc2 im actually looking for that combo myself just make sure your geting all the sensor you need with it
    • Sdcryan1
