need some help with omni4bar
95tsiawd0330
124
Feb 9, 2012
woodlyn, Pennsylvania
when i do a wot pull i hear my bov or wastegate that sounds like a sputter.after the pull i look on ecmlink and see my omni4bar look clean until it gets to around 25psi then thats when it gets choppie.i have checked for boost leak and there is no leaks.here is a clip of a pull were you will see my omni4bar look choppie what will cause this any help will be great.Also my horsepower is low to before it would be around 450hp before this started.
Where are you feeding the MAP sensor from, how long/short is the vacuum line, and is there anything teed into it?
the omni4bar is connected to the intake mani with about 4inchs of vac line and there is no tee on the line.
The "sputter" you describe at high boost sounds like compressor surge. Compressor surge under boost (NOT to be confused with what people often call "surge" when their BOV does not open properly after the throttle is closed) is very damaging to the turbo and occurs when the turbo is operated out of its efficiency range and near the surge line. This most commonly happens at high boost and lower airflows (lower RPM). The jagged Boost trace you're seeing from your MAP sensor in this case sounds normal and is a result of this compressor surge.
Beau
Beau[/QUOTE ] the turbo i have is a 6162 well i found out what was wrong it was the mbc
???? I don't understand what you are asking
Sorry I never saw your reply. What I meant was to power the 4bar sensor and measure it's output voltage while feeding it regulated air.... then find out at what point it gives 5v which would be the largest amount of air that sensor can reliably measure.
