Need some help (weird problem)
fresh83
34
Feb 17, 2009
Detroit, Michigan
alright well if you saw my other post ,you already know what WAS wrong with my car...
i wake up today , and it seemed to drive pretty good , probably @ about 80% of normal .
it builds a boost and accelerated decently but still dint feel like i was gettin the surge of power i used to and should be.
i get to murrays and look at the engine and
and i must have left that unplugged from trying to fix the problem the night before.
but it seemed to fix my boost problem , so i left it unplugged.
then i replace all the spark plugs .
i go to start the car and my A/T temp light , Brake Light and Battery light on my dash come on while im driveing .
and if i really boost they start flickering on and off .
suggestions opinions.
this could be multiple problems that are unrelated .
if it runs better with that pipe off am i hurting anything doing that?
Check for a bad or loose earth, I'm thinking that when you step on the gas something is moving. Have you had your battery off lately ?
