1G Need some advice with parts build list
Alex40823
5+ Year Contributor
31
11
May 30, 2021
San Jose, California
Hey guys so I’ve just started with projecting my parts for my 1g 6 bolt 4g63 build and I want to get your guys advice on what’s better or if it’s ok
Budget is flexible but not gonna go overboard over it so somewhere in the middle kind of budget
Currently this is what I have on:
Speeduino ecu
Adjustable fpr
510cc yellow top injectors
Stock valves, stock V springs
Stock bearings
TD05H 14b turbo
Everything stock except for the injectors and speeduino ecu
What I have but not installed:
BC0101 268/272 camshafts
What I plan on getting:
-Wiseco 85.5mm pistons (K560M855)
-Eagle Rods. 5.9" 4340 H-Beam, Mitsubishi 4g63 6 Bolt, 3/8" Arp 2000 Bolts
-BC0100s single valve springs steel <- I’ve been hearing mixed reviews about these springs so I wanna know what you guys think
-TD05H 16g or 20g turbo
-FIC 950cc low z injectors
That’s all I can think of right now but I’m open to suggestions, reviews and if there’s any better parts than what I listed please let me know since I’m still on the listing phase before buying. Thanks in advance
You can SCARE yourself with this spreadsheet.....but it is a good cost analysis.
As the others mentioned need a goal and plan for you car the more info the better. Ill assume the parts you have picked out already will meet those goals but others will probably wait to comment until they know those goals incase they are not the best option. Id highly consider high z injectors over low z if injectors might need a resister pack removed zero familiarity with that ecu. 16g turbo preferably a mhi evo3 16g is definitely proven and a great turbo. 20g is aswell not real familiar but believe there better options at this time as its a lil older technology but can get a newer billet wheel 20g. you can also get a "Bastard" turbo made possibly best of both those turbos for your goals or a fp 68hta is in that general turbo size as another option. Im not sure if you need rods/pistons with only 16g if your engine is in good health. lot of money that will be spent on a engine rebuild. that could be spent on more supporting mods fuel pump intercooler exhaust boost controller etc. If you are buying rods though check out the eagle rods for 22mm wrist pin. Should be stronger but mainly to give you more piston options. Links below definitely need some more supporting parts on this list.
