Need Quick Help How To Remove/replace Balance Shaft Bearings!!!
rjdavis21
963
5
Aug 22, 2003
Chesterfield, Virginia
I need yalls input on a homemade tool or something to remove and replace the balance shaft bearings. I dont have the right size bearing driver so I need someones input on what else to use. Or the correct driver size to purchase. Please help need ASAP!
This is from the vfaq site: Now you must remove the front balance shaft bearings from the engine block. Get a socket that is the same size as the front bearing and tap out the bearing. Or just place a flatblade screwdriver against the edge of the bearing and tap on it, then move the screwdriver over a bit and tap again, continuing until you knock the bearing out of its' bore and it falls out the bottom of the engine. If you use a screwdriver, be very careful, you don't want to slip and tear up the aluminum oilpump cover
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
