Balance Shaft Bearings
No. You only have to turn the two front balance shaft bearings (balance shaft on the exhaust side). The rear balance shaft bearing (the one the oil pump rides on) doesn't need to be turned as the oil is fed through the balance shaft itself.
VFAQ
