balance shaft bearings
dan2288
577
Sep 9, 2006
Shillington, Pennsylvania
Ok, im about to remove my balance shafts. I have the stubby shaft allready. Which bearings will i need to remove and rotate 180 degrees to block the oil passage?
Cali is half correct. There is one in the block about halfway that you want to turn and then one on the outer edge of the block that needs to be turned as well. However, i would recommend getting new bearings rather than just turning your old ones. $15 is a small price to pay for some reassurance.
James :laser::talon:
