turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Does anyone have a pic from the side or profile view of a GT35Rturbine with the exhaust housing removed? I'm working on a Precision madeMitsu flanged housing that is stamped THM335R which I am going to machine to accept a WH1E/Hx40 turbine wheel and CHRA. I'm doing the measurring to lay out my cuts, and need to see a GT35R turbine to see if that's what this housing is really meant for. I"m curiouse because the volute position is much shallower than a typical T3/T4 or holset inducer turbine blade tip depth.
Anyway, the closer the pic the better if i have to use scaling to base some rough measures, but i would apreciate anything offered
Thanks
Glenn
Thanks
Glenn
, it's not terrible to do as the rear plate closes off the unused area, it'll just be doing more work on this setup but so far measurements so the volute positioning to still be able to let me dothe work
