Need Inline filter to reduce pressure on rs49t Install?
Lordpaxin
1,890
15
Apr 21, 2003
Jackson County, West Virginia
Hello,
I am piecing together a build using a RS49t turbo.
My question is.
I have read several posts about excess pressure curbing spool times.
Do i need to find a way to reduce pressure for this turbo?
2g, feed from 02 housing.
would a Filter Mount Inline with my current oil feed line, designed to come off the L fitting on filter housing and screw into a threaded Nipple mounted inside the Feed port hole.
you all know the type i am talking about.
THanks.
OK, another question.
On the turbo, It has a Fitting screwed into the chra already.
its brass, and the top is a female 1/8th npt fitting like it should have. but the inside of the fitting it has a metal Pin, a circle hole, with a squareish shaped Pin in it, is this a pressure reducer.
It was Installed by AGP and the turbo came with it. im just curous.
