Need info about ceramic coating
hubz91talontsi
1,120
5
Jul 30, 2007
bentleyville, Pennsylvania
Alright, I know that it adds power and reduces under hood temps. What I'm really searching for is comparison dyno results. Trying to calculate a percentage gained by doing this.
Simply enough, you're not going to find much if any.
The key thing to remember is that you have a ton of potential energy in the form of exhaust heat, the more of that you can get to the turbo, the more kinetic energy you will produce. This equates to faster spool times and a more efficient turbo.
You will also have the added effect of lower under hood temps which means a more densely packed air charge which also means more power.... not exactly something you'll easily see on a stationary dyno.
On a side note, you might want to check out Swain Tech Coatings as they're the only place im aware of that sells a true ceramic coating that is more than just looks. Not affiliated with them in any way, i just know they have some great coating technologies.
