Need help with timing belt
Kdouglas89
436
11
Jul 8, 2013
Davenport, Iowa
I have every timing mark lined up, I just cannot get the belt back over the pulley.
I have the tension tool with the 2 teeth on them, but I do not have the belt tensioner bolt that you use to release the pressure.
Is there any other way to compress the pressure without the belt tensioner bolt?
Like I said, the only issue I am having is getting the belt back around the tensioner pulley.
Thanks
Yep, thats how it should look. Notice how the marks are directly in line with each other, and if you look behind them, they are also level with the head of the deck, also, I forgot to mention, but make sure your dowel pins on the cam gears are in the right location as well.
Yep, 12 o'clock.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
