need help with this ASAP!! wire tuck.
vl4bad
130
3
Apr 21, 2012
North NJ, New Jersey
Hello fellow dsm'ers !!
I need help with the following things pics will show what I'm talking about.
I did a fuse box relocation, and had my harness completely redone, and shortened, new connectors and had a bunch of stuff that was crowding the engine bay relocated inside like the fuse box, noise filter, relay, etc. I took this on last year, and was close to completing the installation, i forgot what to do with the last few things & i need some help on the last few things i don't know what to do with. also have another question for the sideband o2 sensor that goes in the exhaust manifold on how to wire that up or where it wires to..here are pics of what i need help with situating and what to exactly do with them:
do i mount them? do i ground them? not sure what to do. shove them under the carpet? doesn't sound good to me LOL
please help ASAP!!!
#3 pic - both should have brackets,i would probably bolt them to the firewall
(left is injector resistor pack,right is ignitor)
#4 pic - noise capacitor should be bolted as close to the coilpack as possible
#5 pic - i believe that is bolted to the frame rail on pass. side (omron generator relay)
#6 pic - i think those are part of the front harness, the one on the right (black)is bolted to the inner pass. side fender well
these were all moved into the passenger side interior,
they don't reach the stock location spots, they were relocated to the interio. i just don't know what to do with them now.
thank you for identifying and giving info. still confused as to what i have to do with them LOL
i would probably bolt them to the metal plate under the pass side carpet(where your abs ecu is).
so atleast there somewhat grounded.
from what i read the noise filter is inline so it shouldnt really matter where you bolt it. (not 100% sure)
thanks, can anyone else confirm this or at least give anymore tips? really would like to get this going already just want to be 100% sure!! thanks
bump
