need help with new turbo choice please help....
kingdaniel04
36
Sep 2, 2004
phoenix, Arizona
i have been saving money and i need a turbo setup that can put me low 12's or high elevens....i was thinking about a t3/t4 57 trim with a .63 housing...and a turbonetics manifold....can someone help me? what kit should i use that will get me there?
If low 12's high 11's is what you only want, then I recommend somthing cheaper and much easier then a t3/t4, I would get the evo 3 16g turbo, they go for about $550-$600 right now. People are hitting mid 11's on this turbo at well over 112mph with stock cams, head and block.
Not to mention the evo 16g will spool a hell alot faster then a t3/t4 will, you will like it much more for the streets. There are a few members on this board that have gone 11's on this turbo. This turbo would put you in the 12's with the supporting mods done to the car, IE fuel system, full exhaust, full managment (afc or the sort)
A 57 trim t3/t4 would be pretty laggy, and you would have to have a good fuel system to handle it.
Look away from the 57 trim, if a t3/t4 turbo is what your looking for, then I recommend a turbonetics t3/to4e 50 trim with a stage 3 exhaust wheel and .63 ar exhaust housing. Best streetable turbo I ever ran back in the day, I went 11.95 @121mph with my FWD with that turbo at only 24lbs of boost. An AWD with good driving it would have been mid 11's easily.
-Jake
