need help with my turbo
DSM's 4 life
649
14
Nov 13, 2011
Buffalo, New York
the oil return bolt on my turbo broke off and i cant seem to drill it out is there anyway i can buy a half a turbo and use my hotside and o2 housing thats on the car so i don't have to unbolt anything?
Any tdo5 turbo will attach to that hot side. Did this happen from over tightening the bolts or just while driving? Most of those cheap headers put the turbo in a slightly different location which causes the line to have pressure on it. That is also an ebay turbo, i would quit buying the cheap parts and you will have less problems in the long run.
yeah I paid 200 for that turbo never even ran it i got scammed and told it was a rebuilt turbo with Garrett parts i bolted it up and the bolt kept spinning so i used a slightly bigger bolt and it broke off fml right...
Definitely leave appropriate feedback if it came from here- doesn't look like that turbo was ever rebuilt to me, and if it was then it wasn't done properly. For less than what you paid you could have bought a new eBay 16G WITH all of the installation accessories.
I'm willing to bet the bolts you were using were too long- they only go up into the housing about 15mm or so. It probably bottomed out and you kept cranking.
A center punch and a left-handed 1/8" bit should be all you need to get that out of there.
