Need help with ms2 setup
you should try and find a portfueler plate so you can run an extra set(4) injectors to control fuel with megasquirt while in boost so you can leave the stock ecu controlling the stock injectors while not in boost. You can have a shop cut out a portfueler plate if you cant find a used one anywhere.
Would that cause it to run any different? Or would that be any harder to tune? Because you could run megasquirt and the stock ECU then and not have to worry about emissions at all and still have it run well
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
