Need help with knock sensor
Logue
408
6
Sep 27, 2003
Tuckerton, New Jersey
i'm putting in my motor in and i was moving the engine wire harness to plug the knock sensor in and the knock sensor connector on the engine harness side the wire broke clean off the connector :mad:
what should i do cut both plugs and make my own? can i buy another plug from somewhere don't really want to would rather cut plugs and make my own?
what would you guys do?
JJ
It's a bi***, but you can get the terminal out of the plug, and put a new one on the end of the wire. Then push it back into the plug. They sell special tools to remove those terminals, or maybe a shop will let you borrow them. Don't make your own connector.
