Need help with install (gauges, TT) Problems after install
Talek
418
Oct 3, 2002
Iowa City, Iowa
Well, I finally got around to attempting to install my autometer boost gauge and air/fuel gauge, as well as my HKS type 0 turbo timer. First off, thanks to everyone that's contributed to the VFaq's, I woulda been lost without em! It still took me longer than I expected... Was a pain in the ass. :p
Car is a 93 Talon TSi AWD.
Anyway, I'm having some problems. I hooked everything up properly, as far as I can tell. The boost gauge works fine. Gets power for the light, and responds properly to pressure. The Air/Fuel gauge doesn't work. It powers on, but it only shows one bar at rich and doesn't change at all, so I assume I mis-tapped the O2 sensor wire. I tried finding the one on the passenger side by the kickdeck, but it must be buried deeper than hell because I couldn't find it anywhere. So, I decided to tap the wire on the ECU and followed the instructions here: http://www.roadraceengineering.com/instructions/afmeterinstallinstructions.htm What should I check? I'd like some ideas of what to look for before I tear everything apart again and try to fix it... I thought it was working fine since it powered up and showed rich at idle. :/
Second problem is that my turbo timer doesn't time. I plugged it in to the harness, easy enough. Grounded it to a spot on the frame. Ran a line to the green wire attatched to the emergency brake. It powers on fine, and lets me change the settings etc and shows the battery voltages. When I turn off my car though, no matter how long it's set to time, it only idles it for a split second before shutting off, instead of the 4 minutes or whatever it's supposed to. What could cause this? I have an HKS type 1 on my other car that I could try and swap in to see if maybe the type 0 is just broken.. *shrugs* blah. Pain in the ass. :p Thanks in advance for any help you guys can give me.
Hmmm after reading the manual for the TT it looks like my connection to the parking brake is probably bad... I bought it used, and there's an old splice on there, chances are it's crappy. I'll fix that tomorrow.
