Need help with FPR installation
BOOSTn20psi
120
Nov 20, 2004
Aloha, Oregon
Ok I've got the Aeromotive FPR. There are three hole, do I use all three? Which line go to which.
2 ft braded goes from side to the stock FPR and bottom 3ft braded goes to where, I'm seeing fuel filter? I've bought the flange fitter that replaces the stock FPR.
How many 90 degees do I need. I've bought 3. Do I need a t inbetween braded lines? The shop suggesting I do.
Here pics of what it will look like assembled.
Left connection with the SS line goes to the stock FPR position, with the new adapter fitting (replaces the stock FPR) (2 foot line)
Bottom connection goes to the return line back to the Fuel Filter (3 foot line)
Right connection is sealed with a provided bolt, given in the install kit
As shown here in the pic, if you get the proper gauge it mounts onto the unit, I think its a 1/8 fitting gauge (Check SBR to make sure)
Top of the unit is where you adjust the pressure once installed.
Im not sure what connects to the little valve on the side someone else will have to answer that.
pic 1
Here is a link to SBR to the filter replacement kit. so all together looks like 3 90's and one 45.
Hope this helps!
