need help with few things
talontsi2011
Banned Member
16
Jan 25, 2011
palmerston, ON, Canada
ok i have few things to say frist. frist thing is on my last post the other day
i got yelled at for miss spelt words i dont understand why its a big deal this is a form and to help people out with these car who cares about spelling some people have problems spelling but still need help
2 i get told to read up about my problems will there 10,000,000 posts here good luck finding what you are looking for so when i asks ?s the people with the big mouths you no it would be nice to point in the right ways and last thing is i have a tranny problom i was asking about but when i go to tranny form i cant post my problem like wtf like thats the point of a form if you are block from posting in 3/4 of the site dont make sence
now more then likey waisting my time again but i have a 95 talon tsi turbo
5 speed all other gears work fine thay all shift mint but i have no rev its like its not there can some1 maybe give me a stright answer
2 i didnt get stright answer on this eather my car has a obd2 plug in it and when i hook my scanner up to it it comes up error dont understand y now my car is 95 and i am in canada but my car is a us car its in mph
Well, you still aren't making a very good attempt at spelling on this post.:(
You know, it really makes it hard to understand what you are asking when you can't spell and you use run on sentences. We have to spend more time trying to understand what you are asking and less time to answer you questions.;)
As for your OBD2 problem, I thought you were getting plenty of answers....
Here it is in case you forgot.
http://www.dsmtuners.com/forums/newbie-forum/390606-just-few-q-see-if-some1-can-help-me.html
It seems like you just disappeared from the thread. :hmm: Maybe you really don't want any help.:idontknow:
Well I am sorry you have gotten some flaming from people on the board. To each his own I guess, but to be honest I am having a bit of a hard time understanding what your transmission issue is. When you say that you have no "rev" do you mean the car doesn't even move when you let the clutch out? Sorry I'm just not understanding what the problem is.
The reason why everyone jumped on you about your spelling is because your asking for help from some of the most knowledgeable people in the DSM world and they want to feel like they are helping person who is smart enough to be able to use the advice they give. So look at it from our perspective... we cant see you, we don't know you, you could be a college professor but the first impression we get from you is shown by your spelling and grammer. It doesn't mean that you are not smart unless you use proper grammer, but when your part of a group that communicates through writing posts you want to give the proper impression. If you have a problem with spelling (i do too) write all your stuff in a word processor first, then spell check it and copy and paste.
Now for your search problems... If your using the search above try changing the "all posts" tab to "titles only" should help weed out a lot of the threads that just happen to mention your problem and then obviously read the "resolved" threads first.
Now for your car... We need a little more info. We do not know what "no rev" means. Does that means its lagging or not building up rpms quickly? Is it cutting out or sputtering or does it sound solid but just doesn't have any torque? Did this start after you replaced anything or did any work or did it just start one day? Cars are complicated so try to give as much info as you can.
Try not to get mad there are a lot of nice people here willing to help. Keep your cool, try not to piss anyone off, and take all advice given to you even if it's about spelling. Welcome to the forum :)
ok frist with the obd problem i plug in my scanner it reads then error any other car it tells me codes.
i have owned then scanner for 2 years now i no how to use it
as for the tranny ya it gose in to every other gear fine but when i go to put it in rev its like it wont go in to gear its like theres no gear there wont even pull down to put in rev its like hard as a rock nothing there
Check your shift linkage at the transmission, see if there are any obstructions. If not then pull the interior shift console off and check for linkage issues there. That's where I would start anyway.
As for your scanner issues could be many problems. That one is a little trickier, I would try another scanner on the car just to make absolute sure the car is the problem.
no my car cold in the morning idles fine but when i drive a bit and stop and sit it idle at 1500 rpm but some times it idels up between 1500 and 2000 rpm back and forth i give it a shot of gas and it stops
but i also have a problem in the morning when the car is cold i can boost to 12 psi when it worm all i can get is 6 psi
ok ty on tranny Q ya i have chacked everything think nothing stoping it everything looks good all the way around i even tryed under the hood with a crowbar pulling it in to rev and nothing i dont no
also i have the new tranny and clutch but dont want to do all that work for something dumb also for got to say my clutch is sliping when i boost but if i drive like a white man its good and shift smooths all 5 gears but no rev
ya i had a friend in car pushing in clutch and trying to pull shifter in to rev will i was under hood trying to pry it and nothing
New clutch could cause big problems with your transmission not being disengaged properly. Does it pop out in first lots? This could be from not having enough travel in your clutch slave cylinder so your transmission does not disengage from you engine because your clutch throw out bearing is not moving the clutch enough.
Go to Jacks Transmissions LLC — Welcome and watch the tech article videos on proper clutch adjustment and pivot ball shimming. This will explain what is most likely happening.
Ohhh so its REVERSE your having problems with. I think most people think rpms when you say rev. Here is a link look at the last two posts.
http://www.dsmtuners.com/forums/newbie-forum/390386-yet-another-2g-5-speed-awd-reverse-problem.html
If your clutch is slipping too, maybe you just need to adjust your clutch. Check your pedal height and pedal freeplay.
WTF does "drive like a white man" mean?
no it dont pop out if any gear drive like a dream forword now i bot this car like this and the guy i bot it from said 1 day it was fine next day no rev and chick engin light came on
Yet another example of how lazy spelling can create confusion.:ohdamn:
This is terrible spelling! I'm done helping you now.:D
I'm trying to be really nice here... you have to spell better if you want people to help you. Open up a word processor and type your stuff in there first before you post to help with your spelling and grammer.
vrs
No it doesn't pop out of any gear and it drive's like a dream while moving forward. I bought this car like this and the guy I bought it from said one day it was fine and the next day there wasn't any reverse and the check engine light came on
There is a pretty big difference here and to some people, myself included, it hurts our brain to read it.
ok will when i say rev and talking about shifting means reverse not reving and driving like a white man means driving car right not banging gears , driving right not fast and stuff any way just tryed ajusting clutch no go , tryed tapping it in with hammer no go so i dont no looks like tranny swap
Correct me if i'm wrong but could it also just be ## clutch plate and pressure plate who are worn out?
Since you checked the pedal response and adjusted it if needed?
Here's a good example as to why spelling is important. Let's say you started a thread titled "Brake problms, ### hlp". Let's say the site members come to the rescue, diagnose your issue, and your problem is solved. 6 months down the road, Joe Blow has the same problems with his car, so he comes here and searches "brake problems". And guess what he doesn't find? Yeah, your potentially helpful thread. Why? Because the search function relies on proper grammar and correct spelling.
And here is an example of why punctuation and proper capitalization are so important:
I helped my uncle Jack, off a horse.
i helped my uncle jack off a horse.
Not to mention that none of us here are interested in deciphering your horrible, butchered up, broken english posts. We're all adults that made it through elementary school. We learned how to properly communicate using the english language, so there's no reason not to use it now.
If you aren't going to abide by our simple rules here (yes, usage of proper grammar is a rule), then please don't post here. It's definitely not up for debate.
If you have legitimate problems with mispelled words, then you need to proof read your posts and use a spell checker. If you use Firebox for a browser, then the spell checker is built in. If you use Internet Explorer, then download and use this: http://www.iespell.com/
