Few things
vegasraverkid
May 2, 2005
Las vegas, Nevada
1. Well my car is a 98 Eclipse GS, and before it went into repair, every time i would start it in the morning, it wouldn start it would kinda start then go off then kinda start then go off finally it would start and like my RPM meter would bounce up and down a bit, then it would go on all the way and like id have to wait a little while because every time i would rev my RPM's would go down and the car would feel like it would stall but never would.
2. I just had a cold air intake installed and like its cool and all i can feel the power but when i push the gas for the first few seconds i can hear a hissing of air from somewhere then it would go away and sound normal.
3. Where can i find motor mounts for my car, dealers in vegas cant seem to get them and shops cant either. :dsm:
If you can possibly IM me and discuss this with me my screen name on AOL is TheTofuNinja and my e mail is [email protected], b ut posts on the thread in response will work to
Thank you
#1Is it only stalling then stops running from a cold start or even when its all wormed up? Do a tune up plugs/wires/and replase your fuel filter, If that dosent help it has been knowen for fuel pumps to act up on start up's like this.
#2 I do boleave the hissing noise is just the sound of all the raw air flowing through your new intake system. Most cold air systems are longer in shape causing more suction, hinse more air movement. It is nothing to be alarmed about.
#3As for your motor mounts i found some cheep ones for you! http://performance.drivewire.com/getparts/index.aspx?pref=Motor%20Mount|MITSUBISHI|ECLIPSE|1998|GS|L4|2.0|122||Engine%20Components I hope this helps! good luck!
