need help with two things???
wills dsm
44
Jan 28, 2005
montgomery, New York
the first one is a minor thing , but nagging i cant seem to get my front washer fluid nozzles to spray. the rear works but front does not , i can hear the motor, but nothin comes out, i have tried just about everything. need to know where the line run to? secondlydo i have to go to the dealer to find out if my abs system is operating properly or can i take to a brake shop :talon:
Its possible your sprayer nozzles are plugged. Try popping the hood and pulling the rubber line off of both of the nozzles and see if fluid pumps out when you turn on the sprayer.
As for ABS, the few shops I went to said that they didn't have the appropriate computer and to go to the dealer for that. You might be able to find a shop that has the equippment, but the dealer is a sure bet. What makes you think your ABS isn't working properly? If there is an error in the system, your ABS light will be on. If its not, take it on a dirt road and slam on the brakes. That will tell you quickly if they are working.
Do you have Fluid, are the tubes connected properly, could be clogged.
Check your abs by doing this... In the rain go about 30mph on a safe street (wide with no one on it) and slam on your brakes. If you skid then your abs doesn't work and you probably need to go to a Dealer to get it checked/removed.
i have tried on wet pavement they slide at all, but they didnt lock up up either. usually u can tell if the abs has been activated . as for on a dirt road, i will try that later.
