Need Help runnin rich boggin down
lowdime23
Mar 25, 2010
Russell, Kentucky
ok well I have a 95 talon tsi with a 6bolt swap mods are greddy bob,50 trim ,1000 cc injectors,hks fmic ngk wires n plugs,wideband dsm link wal 255 ok I took of intake tube to clean it had to disconect maf didn't miss with it at all started car without maf on forgot I know dumb and it ran rich on way home got home hooked up link and couldn't find problem well next mornin wouldn't start changed plugs old ones were soaked in fuel now runs rich at udle and won't go past 3: boggs out I have no idea what to do its runnin so rich it doesn't register below 9 be help would be gret
I didn't spray be thing to it I've learned that lesson LOL how do I check if its bad? Would that cause the car not to go past 3k n run rich
a bad mass air will cause all kinds of problems. see if u can borrow one from someone to try.
I'll try to find one kinda sucks LOL do you recommend what kinda aftermarket one if so which on
do you have a fuel pressure regulator? you're forcing all that gas and have no way to control it.
either switch injectors or get the regulator. also, check for boost leaks as well.
Fixed problem was a bad maf got another one and put a new tune n runs great now thanks for all your input
