2G Need help rpm issue (97 gst)
DSM NE
88
3
Oct 21, 2020
Omaha, Nebraska
Ok so about 2 months into owning my 97 gst and the car was amazing the first 4 weeks of owning it and the previous owner had done some mods to it you can see them on my profile long story short I wanted to get a new radiator fan from mishimoto got the plug n play and it blew tons of fuses a30,a40 and a50 because the connection is wrong anyway and then the cold weather came around and the car started to idle mind you I unplugged the hose to the radiator to put the new fan on and now I have replaced iac valve cleaned egr valve since I can’t find one tried to adjust tps sensor and adjusted biss screw nothing seems to work it’ll rise in rpm when idle and it will stay at high rpm while driving once I let foot off of the gas pedal like it’s stuck and so I took it to two o Riley’s and one advanced auto parts scanner said it was a o2 sensor b1 sensor 2 I also knew because my car has been running super rich I can smell gas and everything and air fuel ratio gauge can’t seem to find a balance always bouncing between 16 to 28 and just yesterday while car was at idle I disconnected the tps sensor and the rpms slowly were dropping slowly but once I plugged it back it started to rise and my apexi gauge said I was on throttle about 8-2% when my foot wasn’t even on the pedal does this sound right tps and o2 sensor is what is causing my issue? Also checked for leaks nothing boost leak tested 3-4 times nothing and yeah water pump is getting replaced right now so I need help any help hopefully those two sensors once replaced and re adjusted will solve it
I don’t think it’ll affect anything. Try to figure out what that 1.8% is and make sure the tps is properly adjusted. Think the link is in one of the earlier posts. The throttle cable isn’t too tight?
Welp a lot of pressure it idled all the way to 2300 and one of the clamps let go now it’s leaking antifreeze
Welp I don’t have my tps adjusted correctly also the cable has some slack I’ll try adjusting tps without playing with cable first then if it don’t work I’ll play around with it
Well rpms are a little bit more controlled it idles at 1200 but also when I parked the car and turned off the heater since my head gasket is blown and is causing my coolant hoses to have a lot of pressure I turn on heater to release pressure when I turned it off it started to idle surge to around 1400
I am pretty sure only the coolant seals on head gasket are damaged since it isn’t touching my engine oil but the weird thing is the car isn’t overheating but then again there’s white smoke water out of tailpipe and I put the coolant hose from the jug into a soda bottle of water and it bubbles a lot
Tps adjustment to .62-.63 volts but once running we put the heater on to release pressure of off the coolant hoses so that they wouldn’t disconnect and leak what If I adjusted tps to 55?
I don’t have ecm or DSM link or anything like that also my biss screw is in pretty bad shape it’s dry and kind of cracked from the head if I screw it in more the idle gets higher so I leave it a little bit out.
Yes the tiny hose from the coolant jug to the main radiator hose will throw pressure or something because we put it in a soda bottle of water and it bubbled more then usual cars but I think it’s only my coolant seals of head gasket because it doesn't touch my engine oil and the car doesn't overheat
Maybe I don’t know the coolant hoses get so much pressure it’s insane but there’s white smoke and water on tailpipe right now car is in the shop getting water pump fixed because when it got back it came back with an oil leak so I took it back to them also the car doesn't boil coolant
This was a fun read. The cooling system is likely over pressurized because you are getting engine combustion into the cooling system from the head gasket leak. I would stop worrying about the idle and fix the head gasket issue before anything else. While the head is off, take the time to clean the throttle body inside and out, replace all the gaskets you can find and look into a tuner or a data logger.
No matter what adjustments you are making right now, the car isnt going to run right with a blown head gasket.
Head was rebuilt no more pressure is being made and fiav was deleted since that’s what was causing the idle much appreciated for all the help and reply’s
