Need Help Quickly Please...
lcanino7914
Dec 9, 2004
Stafford, Virginia
Is it safe to roll a 2g awd eclipse with the front axles removed or will this damage the wheel bearings? If so, can you compress the bearing using a couple washers and a nut and bolt? I've searched this site but not been able to find the answer. I'm pretty sure the haynes manual says something about it but I can't find mine. If
i have moved many cars around by using a big bolt and washers and a nut and it has worked everytime i did it. you will be fine by doing that assuming you use the bolt washers and nut.
