Need help picking rims out...
evanspears1
226
8
Mar 31, 2004
Prestonsburg, Kentucky
Hey,
I have a 1991 Eagle Talon Tsi AWD, and im needin some help on picking some rims...im no good at postin pics, so ill just put the links up...
Konig Incident
http://www.discounttiredirect.com/d...wd=18&c=1&pc=57855&rw=7.5&bp=5-100&vid=006032
Enkei DM5
http://www.discounttiredirect.com/d...wd=18&c=1&pc=60824&rw=7.5&bp=5-100&vid=006032
Enkei PK6
http://www.discounttiredirect.com/d...wd=18&c=1&pc=51111&rw=7.5&bp=5-100&vid=006032
Do-Luck Double six
http://www.do-luck-usa.com/wheels.html
Right now im thinking the Enkei pk6's...i have pics in my gallery so you can see paint scheme...(and if anyone is bored, and wants to do some P/S and put these rims on my car, itd be greatly appreciated)
And if anyone has any other suggestions just post a pic or link or summin...
I also need to know what you guys think would be a good width for them...dont need to be exceptionally wide, just enough to look good...im not real good on this tire stuff...
Thanks,
Evan
i am going to play the card that every did on the kid that asked about his after market fog lamps, which didn't look to bad
they all suck
they all suck
thanks for the input, but what does the top part mean???makes no sense
make sure you get the correct bolt pattern on those rims. The Enkei's are listed as 5-100 and, correct with if I'm wrong, but our cars are 5 by 114 bolt pattern.
sorry just looked again and it says fits from 100 to 114. you're good to go :thumb:
PK6 over the double-six only because the Do-Luck's will set you back $3000 without even buying tires and Enkei's are on my car.
I'd go to 7.5" maximum but 7" would still be a little wider than stock and keep your clearance in line. More importantly figure out what offsets they have that will work with your car.
I like the PK6's Check out the Motegi's I have on mine.
attachment.php
hey d, good lookin rims, which motegis are those??
im thinkin im gonna go with the enkei pks's, i wouldnt even looked at those do-luck rims if i knew that price was for one rim...DAMN...for 3 g's id want a lot better rim than that...
and as far as offset, what would be a good ideal number to look for?
