Need help on springs ###!!
Just because your not on stock shocks doesn't mean it is still good to just cut a spring.
You have to take the shock off to get the spring off, its one assembly then you'll need a spring compressor to get the spring off.
Worst idea.. don't be a cheapass, atleast save $100 and buy some Megan Racing springs. Your insulting yourself here.
im not asking for ideas... you can see that if you can read... some people are just real idiots.. well anyways i already found out how
thanks man
Do NOT cut your springs. Your springs are made to have a certain spring pressure to them and your suspensions was built with them in mind. When you cut the spring, you loose the rigidness needed and your cars suspension becomes a safety hazard. Want to go lower, get real lowering springs that still have the right spring pressure needed for the car.
Also, if you can read you would understand that we are trying to help you out and please read the rules of posting as well. Don't use ellipses for ending sentences either unless you are omiting material.
