Need help Identifying a whine/grind
Jezza
88
5
Feb 23, 2011
Appleton, Wisconsin
Alright fellas. I have a 2Gb Talon AWD w/ a manual trans and have a noise from the front of the car that sounds like a wheel bearing going. The passenger side bearing had some play, so I replaced it, and the whine is still there.
The sound is speed related, not engine speed related. It does not go away when I press the clutch or change when I turn. I changed both the t-case and trans oil to be safe. I'm running out of ideas.
Can the bearing on the intermediate shaft cause the noise? Is my t-case on its way out?
did you check the center bearing on your drive shaft?
I've seen that problem with VR4 and 1G's. not common but it happens.
If you have a local shop that you go to you can put it up on the lift and put the car in gear and listen to the bearing.
If the noise happens all the time then it is somewhere on the input shaft, otherwise its on the output shaft most likely. Talk to jack at jackstransmissions.com, hes very knowledgeable and will be able to tell you what the problem most likely is. Good luck!
The volume and the pitch of the noise increases or decreases with road speed. It is a high-pitched whine at 75-80 and slows to more of a bad wheel bearing-grinding sound around 20 and below.
The sound doesn't change with engine speed.If I hold the clutch in and coast from highway speed to a stop, decreases with the road speed and ceases when I stop.
I didn't think the carrier bearings on the driveshaft would be the culprit since I have no extra vibration that I can feel. I will check those though to make sure.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
