need help identifying a garrett turbo
drethib
63
Jan 25, 2009
Fairbanks, Alaska
i recieved this turbo along with purchasing my talon . i would like to install it but i felt hesitant to know about its driveability. can someone give me a little help identifying this turbo and a brief summary of its performance maybe value?
Garrett A/R-50 labeled on front of compressor housing
M10 BN A on the inside
You will need to define driveability as each turbo has its pro's and con's. Might be a good Idea to ask your what you intend to do with vehicle before bolting on different turbo's. Check out this link TurboByGarrett.com - Turbo Tech101 read all the way through to tech103. May or may not help
Drivability as in for me would be a "daily driver" only means of transportation. I wild enjoy the performance one of these potential turbos can produce but need some reliable information if it's the upper hand decision
If the mods in your profile are up to date any turbo other than stock would do you no good since your are still on stock fuel and have nothing to tune with. I would follow the upgrade path in the tech section, that should take you in the right direction.
I haven't yet I have several improvements since that was last edited. I'll take the time to refresh the profile
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
