Need help finding exhaust housing for big 16G
Captain D
51
Feb 18, 2007
Monument, Colorado
I removed my turbo to rebuild it and 3 out of 4 bolts broke in the turbo housing. The 4th bolt hole has a heli-coil and is so messed up (elongated) it makes the housing not repairable. The rest of the turbo looks fine except the oil seals are leaking which is the reason i am rebuilding it. I have a few questions:
1. Is the exhaust housing the same for 14b, small 16g and big 16g?
2. Does anyone know who sells just the exhaust housing? I tried most of the supporting vendors and everyone sells turbos but only one said they might have a housing but it's going to take a day or two to find it.
Thanks............
Thanks............
the 14b - evo III 16g all use the same hotside. ive got 4 of them myself but they all go to a 16g so i can't sell you one. it shouldn't be to hard finding one though, just put up a WTB ad.
:dsm:
If all else fails I know that bullseye makes a plethra of different exhaust housings for many different turbos I am sure 16g is one of them. Just check out their website.
They actually don't. They all use tdo5 turbine housings, but the size is what varies.
FALSE. :heystupid:
i own a small 16g, big 16g, and (2) evo III 16g turbos which are all currently sitting in my closet next to me. i have ran ALL of them on the same hotside which i have never removed from my exhaust manifold because its setup to run external off the o2 housing. the 14b through evo III 16g ALL USE THE SAME HOTSIDE, its the compressor housing thats different. TRUE.
:dsm:
FALSE. :heystupid:
:dsm:
Are you trying to say that the 14B 6cm housing is the same as the EVOIII 7cm housing?
