2G Need help figuring out whats wrong.
Kdouglas89
436
11
Jul 8, 2013
Davenport, Iowa
To make things short, I took my head off basically I thought i bent a valve. Realized I didn't. I went ahead and upgraded valve springs, seals, and put a cosmetic head gasket on.
The car runs like crap. Hardly any power. It idles fine in park, but once I put it in gear, the idle drops down to about 300, and if I am driving, once I release the gas it wants to die, idling at around 150-200.
I am in time, I did a boost leak test and I am holding air fine. I have not done a compression test yet.
I am having issues with a battery draw somewhere, and Ive had this issue before I tore head off. Its a brand new battery with a new alternator. Car was running and charging fine before I tore head off.
99 gsx w/ 95 ecu. I have link V3 if I could use that to help.
you must have an air leak somewhere or your o2 sensors arent getting a proper reading from an exhaust leak. you can buy gasket material at the auto parts store and cut out the gaskets you need for cheap. Less of a dent on the wallet. Plus i hate waiting for $*** to come in the mail.LOL
ohlegend - New gasket, and from what I see everything is plugged in.
gofast - from my idle log, its .65 at idle, I will check WoT in a minute.
Calan - What do you mean pulling so much fuel? I know I have my deadtime at 555 to keep my combinedFT at as close to 0 as possible. Where are you seeing my open loop thresh holds? That is something I should not have messed with seeing I have no clue what it is!
Thanks for the input guys, and appreciate all the future help.
Kevin
MAFComp sliders, and DA table
MAF was adjusted by dsmlink when I did a cruise log. They were pretty eratic so I smoothed them out a bit. I just compared my open loop thresh holds to a previous log I had, and it is exactly the same. I have not touched that section. I bought link brand new.
