need help fast please! ignition problems
spoolinawddsm
121
Jun 23, 2003
Auburn hills, Michigan
just finished installing my turbo timer (hard wired it) i know im a dumba$$. Now when i put the key in and try and turn it over I get nothing. I disconnected all the wires from the tt and still nothing. Checked under the hood and ignition fuse was blown, replaced that and still nothing. Anyone have any suggestions? I need to drive my car in about a half hour so your help is apreciated!
btw 2g awd.
Thanks
Did you check to see if the ignition fuse blew again after you tried to turn it over?
yes i did, i also disconnected the clutch wire to see if that helped... nothing.
I was alluding more to the method you used to do it - I figured you didn't use a harness.
I can almost gauruntee that you have a bare wear exposed somewhere and it is grounding out.
i am having the same problem except it happened after i installed my fuel pump. although the weird part is that it started and ran fine when i was done and then the next morning, nothing...
i have to get a ride and get some fuses before i do anything tho. besides a bare wire, can you think of anything else...fuel pump wise?
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
