CEL's - Need Help Fast Please!!!!!!!!
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
Ok so My alt took a shit on me so I put a new one on, I get everything on and start it and it dies, try again and it dies again, and throws a Check engine light,
p0443- evaporative emission control system purge control valve circuit
p0403- exhaust gas recirculation control circuit
p1104 -turbo wasegate
p1105- fuel pressure solenoid malfunction
can someone please help me out, I just got the engine rebuilt to a 6 bolt swap and now all this shit happens, Ive had the car back 2 days,
Please HELP
yeah well what happened was I had the battery out for almost all day and the ecu probably reset itself. so after I got all of these engine codes I reset the ecu again and nothing happend but it still would run like shit, Wouldnt even idle. and there was a horrible screetch from the alternator belt area
Well as for the noise try to tighten the belt and make sure the pulleys are not bent. Also I see you have a safc when you had the battery out is there maybe a chance you lost your afc settings making your car run like crap?
