I need fast help, please!!!
DoYuTurbo
34
Jun 12, 2004
mainville, Ohio
my 95 eclipse's headlight is all fogged over. how do you clean the inside of the assembly. it is glued together i've been told u put it in the oven 4 a very short time to melt the glue. please advise me on this my light is out and i need the car tomorrow. please write something!!!
okay if the head light is out, change the bulb. but if u wanna clean inside, heat the glue and take it apart i guess
it would tkae several hours. with only a hair drier. put it in the oven. read the write up on creating 1gA clear corners, should be similer. but seriosly if u just need to change a bulb. dont go through work of cleaning headlight if u dont want ot,
IF your headlights are fogged over on the outside (yellowish) you can Take 1500-2000 grit sandpaper, wet sand it alot, keep spraying it with water, wet sand it some more, and allow it to dry. Then wipe clear any remaining particles with a dry clothe, and apply a layer of car wax onto the headlight for a minute. Then wipe the wax away and you will have a clear headlight.
Not quite sure if thats what you were looking for, but hey it works :)
eric
