Need Help Really Fast Please
yankees1919
134
May 1, 2004
Montvale, New Jersey
I need to remove the oil feed line from the turbo to access the bolts on my oil return line...Anyone know how to do this...PLEASE HEL VERY FAST...
You dont need to remove the feed line to access the return line. All you need to do is slide under the car and remove the 2 bolts holding the return line to the turbo. You will need a 10mm socket, a ratchet and about a 10" extension.
You should bentd the feed line to make access to the bolts. Be gentle because they can be delicate but you should be able to bend it an inch or 2 before you have problems with it. I have never heard of the feed line blocking access to the return line bolts so evidently, it was bent in the first place.
