2G Need Help Diagnosing Idle
Wulf Grace
Jun 29, 2019
AURORA, Illinois
Hello I am a new person to the DSM world and dont really know all that much about mechanics in general, so please excuse my poor use of words :D
, I currently have a 95 Eclipse GST.
This vehicle has been having a very rough idle since I got it.
I recently replaced the Spark Plugs, right before I took the video listed below. Before hand the vehicle would idle poorly and potentially shut off after you apply some throttle. Now since the Spark Plugs were changed, the car still idles poorly and dies whilst idleing.
The vehicle also has evolved and the noise you hear in the video is something new aswell.
Heres the link :
Hopefully some one can help me out :/
Vehicle has
87 Octane Gas but added Lucas Oil Octane Booster
Replaced plugs from NGK bpr6es to Copper plugs from Champion (I just wanted to see if it would make a difference)
A new MAF
Have you done a boost leak test? I found one at my throttle body that is causing a random rough idle, although mine is not as bad as in the video. Also, is the car throwing any codes? Might help you determine what steps need to be taken.
Yeah, agreed on BLT. If OBD1 (not too familiar with how to pull codes on OBD1), go old school and start ruling stuff out. Compression, battery voltage, fuel pressure, mechanical timing, adjustable spark test, noid lights... I mean the list goes on. I wish I was better at diagnosing / trouble shooting but when it’s a shot in the dark. Take the most probable cause or the most likely thing wrong with the car you can think of and go from there.
Edit —> DSMLink would probably make it easy as sh*t on you.
Hello. Thanks fo posting a video. I like the challenge. Correct me if I am wrong but on my iPad I don't see the engine spinning. I hear the sound but I can not confirm that it is spinning. That's number one. Second, any codes, check engine lights? Any recent repair and or work? To me it sounds like 2 things. It's either has a major vacuum leak which I would look into first. Or it has major fuel problem. Now I would not rap my head around fuel problem as I just pulled it out of my ass. So I would first check if their is any codes available. Second I would look into my voltages on the scanner and temps. Third I would look into mass air flow readings and fuel trims. Forth I would look into compression and vacuum possible back pressure. Somewhere along the lines you will have to find a problem but without a scanner or ecmlink it will be pretty hard. So first start with the basic and don't start changing random things. Also something to keep in mind that ignition module the pins get corroded and by moving the connector around it could change the way the car runs. By any chance when you raise the rpm does it start running better? More info would be great, like voltage when the car is running, intake air temp and coolant temp before the car gets warmed up, fuel pressure, compression test, vacuum, back pressure. Things of that nature. First start with vacuum leaks, need to verify that we are not leaking, something that fuel trims would show.
Sounds like the engine is more pumping air than having combustions. Check your major connections like MAF, check for spark and fuel. Check your timing belt. If you get this solved use premium not 87 plus octane booster, and stick to the ngk plugs, change the wires too.
As far as the balance shaft belt goes I never experienced a problem with them so I can not comment on the simptoms but I would think it should not affect how the car runs at idle. Correct me if I am wrong, maybe someone could explain a little more. When my PCV valve hose busted open, my car run just like that at idle. Also corroded ignition module pins made my car run like pop too. Sortently boost leaks did not make my car run like in the video. I had a case at work with 6.0 Tahoe that half of the engine would just run crazy rich and it turned out to be a ground to the coils was bad. With that being said let's start with the basic.
As far as codes, there have been no codes, as well as there aren't any pending codes. :/
Hello. Thanks for posting a video. I like the challenge. Correct me if I am wrong but on my iPad I don't see the engine spinning. I hear the sound but I can not confirm that it is spinning. That's number one.
I can particularly put input on the engine when I rev it, when idling at ~200-1K RPM it behaves like the video, anything more, the engine sounds and appears to run great, and has a consistent feeling.
200 RPM is exactly what it looks like in the video. In your video it looks and sounds like the engine is trying to idle at about 200 RPM which I would think is almost impossible.
Your video is good, it is very clear. And you can see the cam wheels and the belts running which is good.
Could you turn the basic idle set screw (BISS) out to get an idle of about 900 RPM and shoot another video of it idling at that speed? Or 1000 RPM. Somewhere around 800 to 1000. Or if you have to do it with your foot, but then you would need the cam on a tripod I guess.
My car, when it was stock, I always let it idle at about 900 RPM. It was just nicer.
After watching the video. It seems like your only running on partial 4 cylinders. Have you checked your timing Marks?
Make sure everything is tdc and see if your timing is off. If it's off more than half a tooth then it can cause a world of issues at least for me it did.
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
