Need HELP!Car idles then dies after starting, then would not start at all.
v01dy
78
Jun 11, 2005
Auburn, Alabama
I just added some seafoam i tihnk 1/3 of hte can into the crankcase yesterday. Everything was fine up until just now when I tried to start it when it's a like 35-40 degrees outside and basically there would be the normal cranking sound but then after the cylinders ignite, the car would shake vigorously and then die. Also, there is a ticking noise that got louder since I got it and it increases in frequency with the rpm. I used to think it's lifter tick but not anymore. The cel came on, but I don't have anything to pull it off with. Car finally started after cranking it alot after moving it off the incline onto a flatter surface. Got back home and now the car would not start on level surface either. I think I have to call a tow truck....
:cry:
get the code read...
im thinking its ## Camshaft Angle Sensor cause the same thing happened to my car and thats wat the code came out as...
sensor was $90 at the dealership here but u can probably find one at a junkyard.. thats if its the camshaft angle sensor
You wouldnt know for sure until u get the code
yeah it was the camshaft sensor. p3040. Cleared it and it didn't come back on. I'm hoping that the cold just screwed the sensor up. WTF
