Need Help!! 4g15 transmission/4g63t Motor
driverccc
86
Mar 5, 2012
north shore, California
Alright i bought this mirage (with problems)
I plan on doing a rebuild anyways now
When i test drove this before buying the car, clutch was slipping like crazy. so it's now finally gone after 3weeks having it LOL
Now, the previous owner says i can use a 1990 eclipse gst fwd clutch, but hes not sure.
i have a 4g15 transmission on my 4g63t motor. anyone know what clutch i can use or what clutch do i have? if im correct, the 4g15 tranny is from the mirage originally.
the motor swap is off a 90 gst 6bolt 4g63t
any help would be appropriated. thanks
I have a 1996 Mitsubishi Mirage Coupe S
So your mirage has a 4g63t with a 4g15 transmission, and the clutch is gone. Well since you have a 4g63t thats a 6 bolt, i would assume it has the fwd turbo 6 bolt flywheel as well, in which case you would use a 4g63t clutch. I would drop the transmission and verify which flywheel it has before you order your clutch. Its either gonna be a 6 bolt non turbo flywheel, or 6 bolt turbo flywheel.
