Need fuel pump help
Status
Not open for further replies.
IansRedTalon
Mar 5, 2005
Beloit, Wisconsin
Big problem here. Im only getting 7 seconds worth of fuel to my injectors before the car dies. For some reason the fuel pump will prime the system and then upon starting the car will provide fuel for about 7 seconds.
Fuel pump is good. Car runs forever if running 12 volts of the battery.
Fuel pump relay is good. Had it out of the car and went through all the tests.
MPI fuse under the hood is in good shape (has continuity)
Only error code on ECU is for Fuel Pump.
Terminal 10 has 10 volts when the ignition is turned on (should have 12, however i dont believe this to be the problem).
Any advice here guys?
Ian
Ian
Status
