Need Advice with decision
MEz
152
Nov 9, 2011
Gilbert, Arizona
I'm going to buy a complete 6-bolt block that had a torn ripped timing belt of a 1990 gsx and has 90,000 miles on it:hellyeah:. I actually bought the complete head from the guy a few days ago. After I took the valve cover off. I discovered that the head bolts were Hexes(Allen wrench style). Are the hexes OEM. I need help on how to determine if its a virgin block visually(Besides just looking at the head gasket).
Oem head bolts are 10mm hex bolts. You can look at the pistons as well as they should look like this
I want to learn how to tell visually if its been opened before, here are pics of the hex head bolt.
So this engine has never been cracked, But is there any other test to determine if its been worked on before?
I would say if you are that nervous by it then why not take it apart? You can learn a few things in that process as well.
True I mean it is only $50 for the complete block. Just wanted to learn a couple of detail in the process.
Yes I do plan to rebuild it. But I highly doubt it has been machined or worked on because, Like the guys said it still has OEM Head bolts, It only has 90k on it, was driven by a woman(I know a GSX), and I believe the timing belt was never changed.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
