name this screw, help!! [BISS]
josherino
148
Sep 18, 2004
Ft Collins, Colorado
I was changing the gaskets on both sides of the throttle body and I thought the screw sticking upward had something to do with what was holding the throttle body in place, so I loosened it but figured out that I did not need to. I finished the gasket job, but didn't tighten the screw facing upwards and when I took off I immediately lost all pressure, and the car won't stay started, but a lot of air blows through the hole and it dies. I lost the screw and need to know what it is to tell mitsubishi what to order.
sorry, my car is a 90 gsx, but I think that they both serve the same purpose. what is the one for a 1g called?
I got another screw today, but I don't know where it is adjusted correctly? Does it just control the idle adjustment or is there more?
Make sure the o-ring is in there as well as the screw. Tighten the screw all the way in and then out 2 full turns. Check the RPM at idle. Turning the screw in will decrease RPM. Loosening the screw will raise RPM.
I put the biss screw in and im noticing a small idle serge, do I not have it in the right position? I have the o-ring and everything
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
