Resolved Mystery oil filter housing on a used 6 bolt, pictures
jake247
102
Jul 25, 2007
Allentown, Pennsylvania
I picked up a used six bolt when I spun a bearing in my 2g's balance shaft.
I was wondering if anyone knew what this oil filter housing is from, I have never seen this six bolt running, so I don't know if it leaks or seals or what. I could not see any lines for water cooling, or an air cooler. The elephant trunk brass fitting is for my oil feed line for my turbo, i hastily put that on...
I can't get a hold of the guy I got it from (surprise!), I guess he knew what he was doing to me.
Thanks
sweet, thanks. time to go spend some more money for the right stuff.
With an Aftermarket Oil Temperature Valve to go along with your Atermarket Air to Oil Cooler that's a perfectly good OFH for your Turbo - You do NOT want the Water to Oill Cooler Setup although all it would take is the longer Oil Filter Bolt & the Cooler to go that route with THAT OFH.
Yea, just realized it looks as tough it had an external oil cooler. It "could" be a turbo 4g63.
Mike
