6-bolt oil filter housing
blackGSX2g
DSM Wiseman
3,334
88
Apr 30, 2004
Kalamazoo, Michigan
I'm in the middle of a 6-bolt swap and I have a 92 GSX block. Question is, what kind of oil filter housing do I need? Does this come with the oil cooler? I've heard that 89-90 have differen't oil coolers. Do I even need this at all with a 2g?
Thanks
depends on what you want -- 89-90 are air- to liquid coolers
if you want that style get that type of filter housing.
other wise its liquid to liquid from 91-99 you can use you stock 2g housing or the 1g.
i used an air-liquid filter housing. this is necessary for the swap.
also remember to use arp head studs, 1g thermostat and 1g lower radiator hose.
