turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
AS it states... This is a modded lower portion of a TB from a 1g that i just thought i'd see how it works... THere's also a picture of the top of this TB... I middes the top off all the way into the upper mounting holes to get rid of the vacume lines. Then i started building layer after layer of aluminum with the TIG and have it almost where i want it so that i can mill it flat and engrave something in it.
I think this will look nice and clean when done and i'm shopping the mods to the FIAV (both inside and out...there's some stuff you cna't see) buti'm hoping it gives me a perfect functioning idle control without the PITA of a wax pellet and disconnected coolant lines
Share your thoughts!!!
EDIT: the FIAV block looks nasty in that pic, but it's actually reflection from the bandsaw cut marks when i made the slug i welded into the hole. Looks better in person
haha
